midi record with novation remote zero sl
  • the_larch
    by the_larch » Thu Mar 12, 2009 2:59 pm
    Hi all,
    I have a question which may have benn mentioned earlier but I still haven't figured out how to solve the problem.
    I use modul8 with the remote zero sl and I would like to do the following:
    i want to record some midi conroll changings, for example:
    i pull the fader slider 3 times and i would like to record these changes so it could repeat itself automaticly. Is this somehow possible?
    I'm compeletely stupid at MIDI stuffs, so if you know the answer please reply step by step:)
    thx
    the_larch
  • mowgli_uk
    by mowgli_uk » Thu Mar 12, 2009 5:41 pm
    you don't need any midi stuff, just use the layer record or global record function
  • the_larch
    by the_larch » Thu Mar 12, 2009 6:58 pm
    jeez thats more simple than I thought :)
    thx anyway!!!
