Filters module (M8, CI FF ..)
  • poz
    by poz » Mon Mar 30, 2009 12:35 pm
    Hi
    i would like to know what means "Ci" in the filters module, and where to find them on the hard disk (they seem to be integrated to M8 ?)
    How can I duplicate some of these modules ? (to be able to save the same filter with differents parameters in the 4 columns of the filters module)
    thanks
    poz
    by ilan » Mon Mar 30, 2009 3:43 pm
    CI means CoreImage. They are integrated into the architecture of Mac OS X.
  • poz
    by poz » Mon Mar 30, 2009 7:13 pm
    thanks
    where can I locate them in the system ?
    by ilan » Mon Mar 30, 2009 7:33 pm
    As far as I know they are embedded in the OS and there is no way mess around with that.
  • poz
    by poz » Mon Mar 30, 2009 8:13 pm
    I would like to save differents parameters for the same filter (in each of the 4 columns of the filters modules)
    When I use 4 times the same filter (with differents parameters of course), it only saves the first column ..
    When you re-open the document, the 3 lasts columns contains zero values ..
    that's why I thought about duplicating the filter 4 times to use one of each in each column ..
    do you have an issue ?
    thanks much
    by ilan » Mon Mar 30, 2009 8:44 pm
    I consulted David (or mega programmer man) and I stand corrected on the situation with the CI filters:
    additional CoreImage filters could be installed as Image Units and are then located in :
    /Library/Graphics/Image Units
    or
    ~/Library/Graphics/Image Units
    Current version of Modul8 does not ask CoreImage to load these plugins.
    Standard CoreImage filters are embedded in the QuartzCore.framework ...
    nm -a /System/Library/Frameworks/QuartzCore.framework/QuartzCore | grep -i pointillize
    000d3e48 t -[CIPointillize customAttributes]
    000b60c4 t -[CIPointillize outputImage]
    001667bc t -[CIPointillize regionOf:destRect:userInfo:]
    003c6ee0 S .objc_class_name_CIPointillize
    0032ca3c s _kernel__pointillizeStep
    003bd908 b _kernel_ptr__pointillizeStep
    In regards to the save issue:
    I have tested this several times using v2.5.8 saving the document and have had no problems with the custom values getting reloaded. Althogh I was using the L-Filters Ergo Mouse version of the filters module which I prefer using anyway.
    Give that a shot?
  • poz
    by poz » Mon Mar 30, 2009 8:59 pm
    re,
    thanks for the info
    i'll check that and keep you informed !
    poz
    deepvisual
    by deepvisual » Tue Mar 31, 2009 12:42 am
    could you explain the difference?
    I tried it and it seems pretty much the same as the original filters module???
    by ilan » Tue Mar 31, 2009 12:50 am
    It is laid out differently. I prefer this layout because the filter list is larger.
