Soft edge blending WHEN?????
  • MALAKI
    by MALAKI » Mon Apr 06, 2009 9:11 am
    we need it
    by ilan » Mon Apr 06, 2009 12:15 pm
    There will be some time before this will be ready. We want to be sure that the implementation we will make will be satisfactory.
    For now if you are using modul8 there are some very good custom solutions for producing soft edge.
    http://www.modul8.us/2009/03/soft-edge- ... ad2go.html
  • jason5d
    edge blending
    by jason5d » Mon Apr 06, 2009 3:01 pm
    talking of edge blending, M8 is loosing ground.
    Arkaos is being used as a low budget alternative to
    big kit like Vista Spyder, watchout, hippos & Barco encore
    big production forums like blueroom, it's mentioned loads
    Modul8 needs softedge to compete.
    by ilan » Mon Apr 06, 2009 3:16 pm
    We are aware of this. But we want to get this 'right' instead of rushing out due to pressure and getting it wrong. I think anyone would agree that having this implemented correctly is the preferable approach.
  • mowgli_uk
    by mowgli_uk » Tue Apr 07, 2009 12:37 pm
    I appreciate what Ilan is saying. I'd much rather have a solid bit of software than a flakey "let's just get it out" version.
    While we're requesting though, multiple MIDI maps pleaaaase! I'm sure this will be very simple to implement.
    Cheers.
    MIDI mapping makes me...
    by ilan » Tue Apr 07, 2009 12:48 pm
    What do you mean exactly by 'multiple midi maps'?
  • mowgli_uk
    by mowgli_uk » Tue Apr 07, 2009 1:05 pm
    being able to have more than "document" and "default" options. I use different configurations of MIDI controllers for different situations and set ups and at the moment I have multiple md8 preferences files with all the different mappings. Needless to say that though it works its messy and has the drawback of not only changing MIDI maps but other prefs too like the layouts.
    by ilan » Tue Apr 07, 2009 1:22 pm
    Would being able to save mappings as separate files from the project documents be useful?
  • mowgli_uk
    by mowgli_uk » Tue Apr 07, 2009 2:14 pm
    sure.
    by ilan » Tue Apr 07, 2009 2:29 pm
    That will be coming with the newest release as well.
  • mowgli_uk
    by mowgli_uk » Tue Apr 07, 2009 2:32 pm
    good stuff, I can't wait!
    Honestly...
    by ilan » Tue Apr 07, 2009 2:59 pm
    Neither can I.
    pls
    by pls » Tue Apr 07, 2009 3:03 pm
    ok.. getting more and more off topic.. but it seems this could get something like a wishlist..
    so could it be possible to have a manual midi mapping?
    selecting a parameter and typing the prefered midi value in by hand?
    could be much easier than filtering single messages by OSCulator or midipipe..
    by vanakaru » Wed Apr 08, 2009 11:32 am
    pls wrote:ok.. getting more and more off topic.. but it seems this could get something like a wishlist..
    Exactly!!!
    I think M8 would need clear and simple MIDI mapping tool where we could choose multiple MIDI devices to map to different controls. This blind work leads to frustration too often.
  • Ken De Cooman
    by Ken De Cooman » Mon Apr 13, 2009 7:11 pm
    and the timeline feature!!!
    would be so cool...
    probably something for 3.0?
