I agree with this 100%. As it's been mentioned on other posts there's some annoying little bugs-like some layers defaulting their position to the centre when reopening a project. It makes using modul8 for projects that require a lot of prep a bit painful.I do not mind new features in the new version, but much more than that I would prefer perfectly working version.
So that is my wish for the coming release - please fix these problems!
I am talking about modules staying on the screen for ever.- Does this happen with a particular project file or just any project file?
- Are there any particular modules that are being used that might be causing this?
- If you shut off all the modules does this problem persist?
