Is there a maximum video clip size?
  • pixelpirate
    by pixelpirate » Sun Apr 26, 2009 9:52 am
    Have seen in the tech spec that Modul8 renders video at the native file size, and renders to the output resolution, but I wonder is there a maximum file size that can be handled?
    I've a client that wants to project a 3 minute clip of 6613 x 1080 pixels across 3 x 1920 x 1080 windows, the extra pixels are for continuity between the screens. I'm running a MacPro 8-core with 16GB RAM, 4 x 1TB drives (1 dedicated to video clips) and 4 x dual DVI 512MB VRAM graphic cards, and have had no problems running a 1920 x 1080 clip stretched across the three windows, but now need to run an unstretched video.
    Any issues I might run into?
    Thank you very much.
    by ilan » Sun Apr 26, 2009 1:16 pm
    Generally it is whatever your hardware can handle.
    If the clip is just running in a loop and you are not manipulating it in any way then there should be no problems. Very large files will automatically default the memory settings of the clip to 'direct to disk.' This means that the transfer rate of the hard disk is very important.
    We generally recommend Photo-JPEG compression at 75% and this holds true in this case as well. Other users have recommended rendering the movie at half size and then scaling it up within modul8. If the projection is viewed at a distance the artifacts from this will probably more then acceptable for the trade off in performance.
    As always... extensive testing is definitely in order.
    Hope this helps.
  • RickRobiN
    by RickRobiN » Sun May 10, 2009 12:37 am
    Right now I am testing a 5 screen set up.(16x9> 5x 1024x576= 5120x576 )
    For now with this results
    full res> not smooth, stuttering
    (from a internal softraid0 for the video on a mac pro 2008 with the codes Jpg 75 /H264 / AIC )
    3413x384> everything runs fine...
    I think the max resolution is around 4000 with my set up. Pleasy reply if someone else gets higer resolutions on a macpro..
    I can play two 3413 layers in modul8 > one from an internal raid 0 and one from an extranal firewire 800 raid 0, (which it's pretty cool! )
    Pixelpirate, I should go half res with the AIc codec, or try a sdd disk(?)
    cheers RR
  • pixelpirate
    by pixelpirate » Sun May 10, 2009 8:05 am
    Rick - thanks for the update. I've been busy too.
    I've had a short compressed clip of 6613 x 1080 video running smoothly, using the H264 codec, but an uncompressed version stuttered. Have asked to have the clip re-rendered using Photo-jpg codec and 75% compression, and am just installing an 80GB Intel SSD in place of the HDD. It has a 250MB/s sustained read speed. Trouble was only 2.5" SSDs are available here, so took a while to find the right adapter bracket to fit 3.5" bay, it's in the post now.
    Re-rendered clips should be arriving later this week. Looks like testing at the weekend.
    It's good to push the hardware and software, but stability is important here.
    Will post again....
    Richard
  • RickRobiN
    by RickRobiN » Sun May 10, 2009 4:04 pm
    Can I ask which settings you used ?
    Thanks
    RR
  • pixelpirate
    by pixelpirate » Mon May 11, 2009 12:38 pm
    Hi Rick,
    The mac spec is written above, basically one x 512MB DVI video card (nVidia GEForce GT120) for each screen, and one dedicated 1-TB SATA drive for the video clips. 16GB RAM for the Mac too.
    File is spread across three screen, with pillars in between them, so set-up the same way in the advanced output window.
    From the info window:
    Clip 1 - 6630 x 1080 29.97 fps Apple ProRes 422 Codec - worked smoothly
    Clip 2 - 6630 x 1080 29.97 fps Animation Codec - stuttered
    Is this what you want, or deeper info?
    Shall be trying the SSD and photo-jpg/ 75% compressed versions later in the week. I know the clips were not made in ilan's recommended way, but that was the first sample to be made.
    Updates later. Hope this helps.
    Richard
  • RickRobiN
    by RickRobiN » Mon May 11, 2009 6:43 pm
    For now Prores is also not smooth full res on my system.
  • pixelpirate
    by pixelpirate » Thu May 14, 2009 11:17 am
    Rick - was in my local apple store (Ginza) yesterday, talking with the staff there.
    One recommendation from them if doing a 3 screen + control screen set-up was to use two dual dvi-i grfx cards in the 16x slots, and run two screens off a single card, rather than one screen from each of 4 cards in different slots, as slots 3 and 4 are only 4x slots. Data throughput would be better.
    Don't know if ilan and the M8 staff agree, but they felt that the better throughput of data would offset having less vram to work with.
    Richard
  • pixelpirate
    Finished
    by pixelpirate » Tue Jun 23, 2009 10:27 am
    Finished the project - used a 1/4 sized video and the GPUs to scale them up, no trouble at all, no latency. Did it that way as the back-up Mac Pro was an early model with lower spec. A pair of Behringer Midi controllers on both Main (8-core) and Back Up (Quad Core) Mac Pros, while 4 mac minis and 2 Powerbooks provide the outputs when screens were being fed individually.
    Client very happy with the show...
    ...thanks to all for help and advice.
  • RickRobiN
    by RickRobiN » Fri Jul 03, 2009 12:49 am
    Great you found a solution.
    Got some videoshots from that project?
    cheers RR
  • pixelpirate
    by pixelpirate » Fri Jul 03, 2009 3:20 am
    Hi Rick,
    Sorry no video, but have a couple of stills that someone took. Will see if I can work out how to post images here.
    Also have the Video schematic which may be useful to other members, showing main and backup mac pros with modul8, the 6 presentation macs and HD cameras, along with main and b/up projectors.
    Richard
  • philmz
    by philmz » Thu Oct 14, 2010 12:20 am
    we just return from Italia with a new setup :
    New Macpro 6 cores 3,33GHz, 16GB RAM,
    240GB Mercury Extreme Pro SSD for footages
    4xNVidia 120 GT 512 MB (Apple)
    2 monitor output @ 1080p25 to 2 LG 21,5"
    6 output @ 720p25 to 6 ACER P5390W (HDMI, DLP, 4000 Lu, 1280x800 native rez)
    1 canon 5D Mark II feeding HDMI input of 1 AJA IoHD @ 1080p25
    clips compression : photo JPEG 75% @ 720p25 stocked on SSD
    multiple output setup : 6 16:9 1280x720 clips side by side
    result is very smooth with 6 different clips on each output ;-), I still have latency when launching clips via midi keyboard.
    A scene with 6 layers and 6 different clips starts in less than a second, synchro till the end (10 mn longs)
