Midi Question?
  • Grovenstien
    Midi Question?
    by Grovenstien » Thu May 14, 2009 5:52 pm
    Is it possible to have midi control of each layer and the cross fader at the same time? Currently i cant find a way of making that possible!
    At the moment it is possible to control the cross fader and one layer via midi, or control all 10 layers but not the cross fader, i want to control all of it!! :D
    Any ideas?
    Thanks
    by sigmasix » Fri May 15, 2009 1:16 am
    you can make a module for it. it's quite easy, no need of coding.
    Just add a slider or a knob on the visual editor. then go to the keyword connect tab, click on the browse button and select what you want to assign to all your layers.
    Choose " All Layers" under the "in:" popup menu.
    Then, click on the "Map 1" popup menu and chose "Map 2", write "ctrl_master_crossfader_slider" (without quotes) in the "To:" textfield and you're done, your slider will control your stuff.
    Last step, assign your midi control to the slider you just created.
Users browsing this forum: No registered users and 86 guests
