Solo Layer module
  • LeavingSunday
    Solo Layer module
    by LeavingSunday » Sun May 17, 2009 8:24 pm
    I often work with multiple plugins on each layer. When I manually solo a layer in a project, I notice a massive increase in performance.
    I couldn't find a solo layer module that automates this action.
    So I thought it would be handy to have a module that kills the visibility of all layers across all layersets, except of the focus layer. It would be even more handy to have a "kill visibility of all layers in Group A/B" option. So when you have multiple layers active and visible in group A, you can kill the visibility of all layers in group B (on all layersets or only in the selected set).
    To bad I can't program this.. anyone interested?
    by vanakaru » Sun May 17, 2009 10:15 pm
    This is great idea. I noticed this too with my last concert. Because I was not able reopen set up projects the way I saved them I had to use layer sets for every track. It made the M8 very slow indeed. Although it was very convenient to have everything organized this way.
    So I would like this feature a lot. Module or built in.
  • mowgli_uk
    by mowgli_uk » Wed May 20, 2009 6:04 pm
    You don't need a module for that.
    just map all the layer switches in group a to one button/key
    and all the layer switches in group b to another one, voila.
  • LeavingSunday
    by LeavingSunday » Sat Jun 13, 2009 11:27 am
    I didn't think of that, clever solution.
    Vincent-Pimousse
    by Vincent-Pimousse » Thu Jul 23, 2009 12:44 am
    I just saw your post. It is amazing I did a clever solution yesterday, we had the same need...
    http://www.garagecube.com/forum/viewtopic.php?t=4233
