vjjustinallen wrote:I would like to follow-up and ask another question that relates to this. Hope I am not hijacking the thread however.
If I have a 10,000rpm firewire 400 drive and I put the operating system on it, and boot from this drive...how fast is using this external drive as my main drive compared to using the internal drive.
I love having a clean drive strictly for VJ'ing but I am really afraid of performance issues.
Bucharest wrote:I only use external hard drives for any show FW 800 with a raid 0 configuration at 7200 rpm.It works like a charm ...I never had any problems with it...I am planning to use the same case http://www.galaxymetalgear.com/products/3500_mgbr.html for a 10.000 rpm raptor hard drives ,much more responsive... As is , it is very fast ,but you know how it is ...I want more and more speed.
Sonicocr wrote:Fry_up.... man I just get a Lacie Rugged and it doesnt work on my FW800 port.... it turns off after few minutes... It only runs on the FW400 format. In the Lacie support forum they say it is a problen with Rugged design and his ability to get power from the FW800 bus.
Plz tell me, How you make it work in FW800 on a MBP? You use the adittional USB power supply cable?
gmint wrote:I don't want to rain on anyone's parade here, but it seems to me that some people (I'm not referring to anyone in particular here) go with an external drive just because they assume that it will be faster.
anomad wrote:gmint wrote:I don't want to rain on anyone's parade here, but it seems to me that some people (I'm not referring to anyone in particular here) go with an external drive just because they assume that it will be faster.
. i've been of the mindset that it's better to keep the data off the same drive as the system HD, especially when running a lot of video/audio files at the same time.
. though, i agree that for many applications running on the internal HD is probably enough
Users browsing this forum: Baidu [Spider] and 24 guests
