A>B becomes A+B
    Jesper Fryd
    A>B becomes A+B
    by Jesper Fryd » Mon Jun 27, 2005 8:46 pm
    Really love the new A<>B mixing feature of V2, although:
    If all my layers in A have transparent background (via luma key or alpha), then the layers from B are visible underneath.
    I can see why this happens, since you basicly just split the old 10 layers into 2x5.
    But I am not sure if this behaviour is to be considered a feature or a bug...?
    It basicly means that I have to waste layer 5 with a black solid if I want to have transparency in A...
  • moonbase
    by moonbase » Mon Jun 27, 2005 9:41 pm
    Hi Jesper, you need to enable your prefered option of A and B fading or scaling on the fader section and all is as you wish! x x
    Jesper Fryd
    by Jesper Fryd » Mon Jun 27, 2005 10:25 pm
    ah, on both on them. now I see.
    up until now I would only set "fading" on A.
    cheers :)
    VJFranzK
    x ray vision
    by VJFranzK » Wed Jul 06, 2005 4:12 am
    actually, that happens even with both set to "fading".
    as layer set A is fading out, you can "see through" opaque parts of the top layers
    (this only becomes apparent when you have several layers stacked up in A and B)
    it could be considered "a bug", though most won't notice?
    Re: x ray vision
    by boris » Wed Jul 06, 2005 1:51 pm
    Is it not a fading from A to B.
    Is it a transparency fading of each layer on the group A and each layer on the group B.
    Is not a Bug...
Users browsing this forum: Baidu [Spider] and 44 guests
