Text Module Problem
  • Daniel G
    Text Module Problem
    by Daniel G » Wed Jun 29, 2005 1:34 pm
    Hi Everyone!
    I have searched the forums without luck, so I will try posting myself:
    Im running Modul8 V2 and the text module wont accept any text input?
    Can anyone help me with this? Thanks in advance!!
    -Daniel...
    Details:
    The text module seems to work fin until i select the text field - It selects it, but the text cursor doesnt show up.
    I have tried to remove all fonts from my Library/Fonts, leaving only preinstalled fonts.
    When I switch user - To a "clean" account and runs Modul8 from there it works?! (This would be very annoying to use it this way though)
    by sigmasix » Wed Jun 29, 2005 2:13 pm
    try to remove the .plist in you preference folder
    ("com.GarageCUBE.modul8.plist")
  • Daniel G
    Tried it...
    by Daniel G » Wed Jun 29, 2005 4:09 pm
    Thanks for the tip ... Unfortunately it didn't help?!
    Any other suggestions?
    Thanks a bunch!
    Daniel
    yves@garagecube
    Re: Tried it...
    by yves@garagecube » Fri Jul 01, 2005 12:10 pm
    Thanks a bunch!
    Daniel
    Hmmm... This is weird. If it works with other user accounts, it means that it has something to do with your local user configuration. What is the language of your user ? What version of the system ?
    yves@garagecube
    Re: Tried it...
    by yves@garagecube » Fri Jul 15, 2005 4:36 pm
    I was able to reproduce this problem by deactivating the Monaco font. This font is used by Modul8 and should not be disabled. Please verify that it is enabled in the "Font Book" application. Also if you are using another application to manage your fonts, check that it does not disable the Monaco font.
    Jesper Fryd
    by Jesper Fryd » Sun Jul 17, 2005 9:09 pm
    I know that Daniel rarely drops by the forum, so I have e-mailed him your reply - and on his behalf: Cheers! :D
  • Daniel Gjøde
    Text Module Problem
    by Daniel Gjøde » Sun Jul 17, 2005 9:31 pm
    Hi Yves,
    Thanks a bunch!
    I have now upgraded to Modul8 2.01 and i have reinstalled all my fonts... With Monaco enabled... And now it works!! That's really great...
    I dont know if it was a font problem or the new Modul8 thing fixed the problem - But now it works and thats really great! Keep up the really really good work!
    Take care... Daniel
