. anyone use modul8 to trigger videos clips w/audio?
  • anomad
    by anomad » Sat Jul 11, 2009 8:47 pm
    . i'm a big fan of Meat Beat Manifesto and Emergency Broadcast Network and have been working video clips w/sound into my synthpop/dance music. i've been using modul8 for some basic clips and was wondering if anyone else is using modul8 that way, and if they had any tips/tricks or suggestions to make the process more consistent.
    . mainly, i've noticed that i can not ram preload/uncompressed the clips (even very small ones) and have them ready to trigger at a moments notice.. there's often a small delay in the trigger for the first usage of the clip, but subsequent triggers of the clip play quickly. is there a way i can have a clip 'ready to go' before triggering it?
    . also, on a different note, does anyone know of a good resource that describes how to end a video clip on a transparent frame? i've been working w/adobe after fx/premiere w/no luck in adding a transparent frame to the end of a clip (compressed animation/millions of colors+) - i always end up with a black screen.
    . thoughts/ideas are welcome!
    -james
    (a nomad. )
    deepvisual
    by deepvisual » Sat Jul 11, 2009 10:34 pm
    if you have a transparent frame, but nothing underneath it, M8 will output the background.
    I just made a png+ clip with the last few frames transparent and it worked fine???
Users browsing this forum: Baidu [Spider] and 46 guests
