simple mapping issue
  • bdeschryver
    by bdeschryver » Tue Jul 14, 2009 2:21 pm
    Hi VJs,
    I mapped a slider of my midi controler to the group A/B slider in Modul8, as I guess everyone does.
    I was wondering if it was possible to map also two push buttons of the same controller to whatever function in M8 so that I could flash the A or B group. These buttons would provide the same effect as sliding the fader to A or B side, but quickly.
    For those who use it, it would be identical to the transformer key on the Edirol V4.
    Any idea to which part of the M8 interface I have to map them to ? or should I build a module ?
    Thanks
  • dRead
    by dRead » Tue Jul 14, 2009 11:27 pm
    look for these modules in the online library:
    (s6) Cut (all)
    CrossFader (master)
    I think Sigmas Cut module is like hitting the A/B Trans buttons on a V4, the crossfader modules toggles between a/b with a user set time.
  • bdeschryver
    by bdeschryver » Wed Jul 15, 2009 10:56 am
    thanks for your input, I'll get that tonight !
