VMX VJ
  • boil8014
    VMX VJ
    by boil8014 » Mon Jul 20, 2009 1:42 pm
    What is the best way to map the VMX. It seems difficult because you have many images in one dock and are unable to select them individually with the VMX. This makes it hard to select an effect on each clip. Also there does not seem to be enough buttons to map to all the options on modul8. Can anyone help.
    cheers, Boil
  • mowgli_uk
    by mowgli_uk » Wed Jul 22, 2009 11:12 am
    What do you mean with "one dock"?
    You can't expect to have a physical controller for every parameter in md8, figure out what you need and map that.
  • b1w7m5lwb4
    by b1w7m5lwb4 » Wed Jul 22, 2009 9:57 pm
    tedious, no? it's almost like.. you have to work at it a bit. i'd suggest, let the VMX sit out for a bit, work out a +-30 minute set with just the mouse, and figure out from there which parameters you want to change with your controller during performance. there's no set formula to tell you what to do, which is why we all love professional creative software.
    deepvisual
    by deepvisual » Wed Jul 22, 2009 11:24 pm
    I had one until recently
    had a button for each clip and another button for each tab
    also had a slider to scroll through the layers and then one slider for each layer transparency
    hardly used anything else.
  • boil8014
    by boil8014 » Wed Jul 22, 2009 11:25 pm
    It's cool i got it all under control. I was over complicating things. One problem I'm having though is that the jog wheels don't seem to be scratching properly. All I can seem to get it to do is start the clip from the beginning each time I turn it. Is there something I can do about this.
  • mowgli_uk
    by mowgli_uk » Thu Jul 23, 2009 1:00 am
    have you got the vmx vj module?
    that should sort it out
  • b1w7m5lwb4
    by b1w7m5lwb4 » Thu Jul 23, 2009 3:28 am
    re: scratching. sometimes helps to set the speed of clip playback to null, depending on what yer doing.
