Text modul : bigger size ?
  • Paul Sellis
    by Paul Sellis » Wed Jul 22, 2009 11:40 pm
    perhaps I am mising something because I am a Newbie with Modul8, but I don't find a way to get a larger size for fonts than 110.
    Is it possible ?
    May be in the module file TEXT (layer).m8m directly ?
    Thanks you for your help...
    Paul
    by vanakaru » Thu Jul 23, 2009 1:20 am
    yes, you need to edit the text module in editor. Modules>Editor duplicate text module>d-click on text module>Text controls>click on size num. box above the size radio button and change the max (110) to 600. Close editor. This works only when you use numeric box for text size. Touching Radio button will jump back to 110
  • b1w7m5lwb4
    by b1w7m5lwb4 » Thu Jul 23, 2009 3:32 am
    why not set to max font size, then increase scale in layer?
  • vj_ava
    by vj_ava » Thu Jul 23, 2009 4:29 am
    Pending the resolution being used you can get pixel distortion.
  • Paul Sellis
    by Paul Sellis » Thu Jul 23, 2009 8:08 am
    OK Thank you ! It works great.
    Just too bad that using Radio button jumps back to 110...
    Well I have 2 more questions on this module : :wink:
    - is it possible to anti-alias text ?
    - any way to correct interlining values ?
    :roll:
