PC broke down - A Sign?
  • amiko
    by amiko » Fri Jul 24, 2009 4:07 am
    Is this the time to switch to Macbook pro? Money is a factor so for now i can afford the Macbook pro 13” 2.53Ghz with NVIDIA GeForce 9400M graphics 256 MB sheared with main memory. this could be also an upgrade from a vj application like visual jockey.
    will it run Modul8 with no problems? will it run other applications like AE- PS cs4 with no problems?
    thanks in advance for the patience with a newbie like me
  • NLS6XX
    Re: PC broke down - A Sign?
    by NLS6XX » Fri Jul 24, 2009 12:16 pm
    amiko wrote:Is this the time to switch to Macbook pro? Money is a factor so for now i can afford the Macbook pro 13” 2.53Ghz with NVIDIA GeForce 9400M graphics 256 MB sheared with main memory. this could be also an upgrade from a vj application like visual jockey.
    It will run everything without too much problems (if any). BUT everything will run better and faster on a heavier MBP. Save up a couple of months more and get yourself a 15" MBP with 512mb dedicated Graphic Card and at least 4gigs ram.
    Also keep in mind that a 13" display will be quite small for vj purposes.
    Don't go cheap on your first Macbook Pro... It's better to wait a month more and don't regret it than to regret it after a month. :wink:
    Greetz,
    NLS
