(vp) Sync Fading module
    Vincent-Pimousse
    by Vincent-Pimousse » Sat Jul 25, 2009 2:49 pm
    Hi all,
    I wrote a simple module, give me feedback if you want I improve it.
    The module is "sync fading" that you can find on the public online library.
    It looks like that:
    The aim is to Synchronise the fading fonction of layers as a master parameter.
    I would like say "fading function" by the following part on the M8 interface:
    I realise you could do the job by midi mapping. See the post how can i activate the 10 layers simultaneous?
  • zerpo poursuit
    Re: (vp) Sync Fading module
    by zerpo poursuit » Sat Oct 22, 2011 11:03 pm
    hi guys,
    sorry for my french.
    maybe i've been in the black box for too long but i can't make it works.
    in the module,
    i select some layer, activate/deactivate the Sync fading button and...
    nothing happens.
    in modul8,
    i play with my layer's fading options, activate/deactivate the layers, play with their fade and...
    nothing happens.
    can i be dumb or what ?
    thanks for help.
    enj8y
Users browsing this forum: Baidu [Spider] and 20 guests
