Fullscreen randomly fullscreens on the wrong monitor
  • kaotix
    by kaotix » Sun Jul 26, 2009 6:28 pm
    my computer has a second monitor, i was using modul8 demo for a while and it was full screening on the second monitor naturally
    and then out of nowhere it starts to fullscreen on my primary monitor, it still automatically previews on the second monitor in windowed mode but fullscreens over to my normal one, anyone have any advice for fixing it? as it does the same thing when i plug in my projector, previews on the projection then fullscreens to my monitor
    many thanks in advance, as this would almost render it useless if i purchased it and wanted to use it in my set up
    deepvisual
    by deepvisual » Mon Jul 27, 2009 1:32 am
    could be a couple of things.
    in M8 make sure advanced output setup is turned off.
    in apple/systems preferences/displays/arrangement make sure the white menu bar is not on your output monitor, if it is, drag it back to the icon for your computer screen.
