Sound in from itunes, sound out integrated speakers, how to
  • dizzus
    by dizzus » Wed Aug 05, 2009 10:54 am
    there is soundflowerbed installed now on the machine. modul8 only seems to "get" the sound when choosing input soundflower 2ch aswell as output sondflower 2ch in the system preferences but this way you are not able to hear something yourself which is what i´d want to
    Valparaiiso
    by Valparaiiso » Thu Aug 06, 2009 12:51 pm
    You can use LineIn to monitor your sound input and direct it to another sound output.
    [EDIT] I edited the link so it doesn't download the app when you click it but go to the detail page
    FlyingLobster
    by FlyingLobster » Fri Aug 07, 2009 5:15 pm
    I also use Linein to get an external sound input to Modul8, but I don't think you can hear it on the output/speakers.
    Could you confirm it is possible ? if so, how to do it ?
    Thanks
    Valparaiiso
    by Valparaiiso » Fri Aug 07, 2009 7:14 pm
    In LineIn, select your sound input, select your desired sound output, click on PassTrough button, you are able to monitor your sound input AND M8 too.
