Hey
Would it be possible to use modul8 to project onto 5 surfaces - 4 walls and the cieling?
i will have 5 seperate clips to play but need them synched and they will be projected onto large walls so they will be large in size.
w://
ilan wrote:It is possible. You will need a Mac Pro with multiple video cards to do this. Use the BPM module and the BPM layer router module, 'pick' the 'scratch' knob for each layer and then trigger all of the clips at once.
To trigger all of the clips at once assign the same key or midi binding to trigger each media for its layer using the 'position' mode.
