external hard drive?
  • mannikin
    by mannikin » Tue Jul 05, 2005 5:14 am
    I'm using my Powerbook 15" 1.5ghz with Modul8. This PB has a 5400 RPM drive. Is this enough to run the media, or do I need an external HD (firewire or firewire 800) for my media? Any advice would be appreciated.
    Thanks;
    J.
    VJFranzK
    by VJFranzK » Wed Jul 06, 2005 4:02 am
    That's what I'm using. It works quite well as-is,
    but might buy an ext. HD for even better performance (many layers, hi-rez)
    Question: Can you get faster performance by using clips
    off two HD's simultaneously? or does that "confuse" the machine
  • studioc
    by studioc » Wed Jul 06, 2005 6:55 pm
    If you are streaming clips that are too large for RAM off the hard drives, they should benefit from a dedicated hard drive per clip, since the hard drive will not have to seek more than one stream at the same time. As a rule, don't use the application's drive for streaming video.
    The Revolution must be televised!
