media preparation questions?
  • mannikin
    by mannikin » Tue Jul 05, 2005 9:21 am
    I read the section in the FAQ, however I still had the following questions:
    - I exported my movies from Final Cut, and used Compressor to batch them to 512x384 using Photo Jpeg. What frame rate should I be using? I kep them all at 29.95. Should I use 15fps to speed playback?
    - Should I deinterlace the movies? I plan on using a projector.
    Thanks;
    John
  • stuart
    by stuart » Tue Jul 05, 2005 7:21 pm
    Certainly the movies should be de-interlaced. Experiment with what you have now to determine what your performance needs are. If you are bogging your machine Modul8 will happily drop the frame rate for you :wink:
