Modul8 and Mac OS X Snow Leopard
  • te-c
    by te-c » Tue Aug 25, 2009 10:29 am
    Snow Leopard is on the market now. Is anybody out there who's checking the compatibility with modul8?
    Tell us your experiences...
  • woolfeo123
    RE: Snow Leopard
    by woolfeo123 » Mon Aug 31, 2009 11:28 pm
    i have had a major messup with my version of Modul8. Everytime i open the application, it asks me to activate it. I got through the process of activating, says it is authorised. Then when i re-open the program it asks me to activate all over again. Just keeps doing the same thing over and over. Can anyone help??!
    :x :x :x
    nestor
    by nestor » Tue Sep 01, 2009 2:47 am
    like a pirate version
    by vanakaru » Tue Sep 01, 2009 9:34 am
    nestor wrote:like a pirate version
    been there, done that?! or what?
    I have seen this happen when pref file gets screwed and when my motherboard got replaced. So every time I do any major installation like new op system, new HDD - DE-AUTHORIZE your copy. For now you can ask garagecube team to de-authorize all machines you have M8 running and you can start again.
    by ilan » Wed Sep 02, 2009 6:47 pm
    We also need to know your serial number and what version of modul8 you are currently using.
    Would be very helpful for us to know what is causing this problem.
    nestor
    by nestor » Thu Sep 03, 2009 2:45 am
    Sorry, I meant no offense, I say that it behaves like.
  • dipalina
    by dipalina » Wed Jan 13, 2010 12:00 pm
    Could installing mac os x on a PC damage the hard drive? I am gonna install mac os-x on my PC. If I do, will it cause any damage to my hard drive or any other hardware? Because it is not ruining on its native hard ware, I thought it might do some amount of damage.
    __________________________
    keyword research ~ keyword tool ~ keyword tracking ~ affiliate elite
    by vanakaru » Wed Jan 13, 2010 12:36 pm
    It is the wrong forum to ask this. Try google hackintosh.
    You should be asking does anybody run Modul8 successfully on hac.
    But generally - op system is software. Unless you overheat something nothing going to happen to your hardware. If my answer is wrong and you fry your PC for good then my first comment is even more true.
    spam is not real food
  • R-e-R
    by R-e-R » Tue Jan 19, 2010 10:21 am
    i run m8 on sl 10.6.2 with no issues if thats what the op was asking
    hedgemunkees
    module 8 + snow leapard
    by hedgemunkees » Wed Feb 24, 2010 6:54 pm
    if all your software is legal you should have no probs. Mine works perfect.
    regards
    bev
    Vincent-Pimousse
    by Vincent-Pimousse » Sat Mar 13, 2010 11:21 am
    I just upgrade my mac, deleting leopard and installing snow leopard. I am registered for M8 2.5. Is there a specific M8 2.5 for snow leopard?
    Should I install the only M8 2.5 I have, and then upgrade it OR download a specific version?
    Cheers,
    Vincent
    EDIT: You can have the link to download the last 2.5 version: http://www.garagecube.com/modul8/yourspace/
Users browsing this forum: No registered users and 53 guests
