midi trigger.....button behavior
  • earsaregood
    by earsaregood » Tue Aug 25, 2009 9:55 pm
    When I trigger a function like layer on/off for example....I can't get the button to stay "on" after I release the trigger....?
    So I can't press the trigger, engage the layer, then move on with the layer still playing..?
    Is this right?
    Matt
  • anomad
    by anomad » Wed Aug 26, 2009 2:32 am
    . it's acting as expected. when the layer sees the assigned midi value > 0, it turns on. when you let the key off, it see the midi value == 0 and turns off
    . you might want to create your own module (not really that hard once you get into it) and create the button that controls the layer on/off as a toggle - so when it sees an assigned midi value > 0, it changes its status to on or off (the opposite of the last state)
  • earsaregood
    thanks
    by earsaregood » Wed Aug 26, 2009 2:54 am
    thanks
    deepvisual
    by deepvisual » Wed Aug 26, 2009 7:02 am
    probably easier to do this on the controller.
    just use a latch switch instead of a push button.
  • earsaregood
    Latch
    by earsaregood » Wed Aug 26, 2009 4:39 pm
    Yeah.... A latch... I'm using an old Oxygen8 and I don't believe it had this functionality built into the hardware.... But the latch concept I'm very familiar with from audio work...I can already see I need to make modules....but any comment on a righteous midi controller fir m8 would be appreciated....
    Cheers everyone..... And thanks for the active forums/support!
    Deepvisual: watched your beat/dance match with kaptivator video... Nice...inspired to jive talk my way through today
