How can I pause a Live DV Source ?
  • Paul Sellis
    by Paul Sellis » Thu Sep 03, 2009 7:39 am
    it should be obvious but I don't see how I can pause the Live DV souce...
    (I mean get a static image)
    Thanks for your help.
    Paul
    by ilan » Thu Sep 03, 2009 8:44 am
    The simplest method for doing this is turning trace all the way up and then hiding the layer. Could be a problem though if you have other stuff running over it.
  • Paul Sellis
    by Paul Sellis » Sat Sep 05, 2009 9:23 am
    Sorry for the delay of my answer.
    But what do you mean by "turning trace"
    (I initially thought it was a module to turn on ! :lol: )
    by ilan » Sat Sep 05, 2009 2:55 pm
    Bottom right of the main interface. The 'trace knob.'
    by The Midi Thief » Sat Sep 05, 2009 3:22 pm
    I got inspired and did some experiments. It resulted in a module called "(i) Pause All + Video Capture". Basically it works like the "Still" button but also effects the video capture. It's based on Ilans explanation above.
    Hopefully it makes it a little bit more convenient for live situations.
  • Paul Sellis
    by Paul Sellis » Sat Sep 05, 2009 7:10 pm
    8)
