Hidden Group...
  • Paul Sellis
    Hidden Group...
    by Paul Sellis » Thu Sep 03, 2009 10:23 am
    sorry again for this newbie question :
    when I reopen a previously saved Modul8 project it happens that complete Groups (or some layers) don't show anything in the Output even if I don't have modified anything (as far as I know...).
    I have to remove layers and then recreate them one by one... :oops:
    Is it a known bug in the 2.5 version or is there something I do wrongly ?
    Thanks
    by ilan » Thu Sep 03, 2009 12:10 pm
    For future reference please post support type questions in the support section of the forums.
    Are you moving your media around? Changing its directory?
  • Paul Sellis
    by Paul Sellis » Thu Sep 03, 2009 11:43 pm
    I didn't move the medias.
    I have the same problem also with Live DV input.
    No idea of what it could be ?
  • Paul Sellis
    by Paul Sellis » Tue Sep 08, 2009 10:42 am
    It came from the "Crop layer" module. :shock:
    I need to reset it or disable it and it seems to be OK.
    A known bug or may be I use this module in a wrong way...
    by ilan » Tue Sep 08, 2009 12:08 pm
    You're using the Filter module for this? What version of the filter module? There are several user modified ones.
  • Paul Sellis
    by Paul Sellis » Tue Sep 08, 2009 12:20 pm
    I use Filter (layer) Module in this project but not for cropping...
    I use the Crop Layer (Udart) module.
    Do you advise me to use the M8 Crop from the last Filter module version ?
    by ilan » Tue Sep 08, 2009 12:40 pm
    You might want to try that. Sometimes user created modules can cause problems. We don't screen them so it's kind of free for all.
  • Vibber
    Re: Hidden Group...
    by Vibber » Tue Feb 28, 2012 2:33 pm
    I have become aware of the problem in the Crop Layer module that I developed. I have uploaded a fix today so please for anyone who wishes to use this module - please redownload it from the library.
    (By the way for anyone interested it was actually caused by a bug in Modul8 regarding defualt values but I found a workaround that I think will solve the problem)
    Re: Hidden Group...
    by ilan » Thu Mar 01, 2012 3:39 pm
    Great work as always Vibber!
