Locked 15 posts Page 1 of 1
Modul8 v2.6 public beta release
    by ilan » Mon Sep 14, 2009 8:30 pm
    Hello everyone,
    GarageCUBE has released a public beta of modul8 v2.6. It includes several new features and fixes as well as compatibility with Mac OS X Snow Leopard.
    This public beta is free for testing to all registered users and will expire at the end of this month.
    The final release will be a paid upgrade of 49 euros. For users who purchased modul8 within the last year the upgrade is free.
    DO NOT USE THIS VERSION OF MODUL8 FOR PRODUCTION PURPOSES.
    Features and changes
    - Compatible with Mac OS X Snow Leopard.
    - Irresponsive and blurred module buttons in Snow Leopard.
    - Screenshot of preview/output.
    Sound Analysis
    - Sound Analysis Configuration panel accessible using 'Edit > Sound Analysis.'
    - Apply sound analysis through the Animation FX menus.
    - New function for modules: modul8.getSoundBands() returns the 23 bands (20:low, 21:mid, 22: high)
    - Adjusting the sound input level within modul8 changes the default input level in System Sound Preferences.
    Layers / Media
    - Increased live video feed to 4 simultaneous streams. Cameras can be assigned to the inputs available in the Special Media panel using the QuickTime preferences panel in the Video Capture preferences.
    - Dragging and dropping a folder with images into the media set creates a sequence that can be controlled like a movie. Adding and removing images from the folder will dynamically modify the sequence within modul8. The maximum pixel size of movie folder can be set in the preferences under the Misc tab.
    - Additive and subtractive blend modes made available for all layers.
    - Wacom tablet input is available in the module system. The Paint module has been modified to take advantage of this feature.
    - Sound balance can now be controlled in the Opt. tab of the main layers interface.
    DMX
    - DMX support available exclusively using the Enttec DMX USB Pro device.
    Using the module system it is now possible to control modul8 using DMX and to control DMX devices using modul8. Fully functional and sample DMX modules are currently available.
    - DirectEvent returns a new type: DMX (universe, channel, value, timestamp).
    - DMX functions for modules: getDMXUniverseList, sendDMX, getDMXValues.
    MIDI / Keys
    - Automatic scan of MIDI devices when they are connected or disconnected.
    - Added the option to filter MIDI devices. The filter is located in the preferences panel under the Key/MIDI Mapping tab.
    - Import/export of MIDI and key mappings.
    New module keywords:
    direct_snapshot_mainOutput
    direct_snapshot_previewWindow
    direct_preview_position_z
    direct_media_bilinearFiltering (write only)
    Preferences
    - The preview window can now be customized to any pixel size. This option replaces 'free mode.' Also added is a preset for 16/10 aspect ratio.
    - Rendering size of Quartz Composer file can be set in the preferences under the Misc tab.
    Bug fixes
    - Added missing and or incomplete descriptions to the keyword browser.
    - Modul8 was not receiving data from Korg nano kontrol when two controls were used simultaneously.
    - In a specific instance the alpha IN/OUT buttons in Transformer/Particles were not updating.
    - In some instances preview tabs disappeared when playing back a Logical Record.
    - In the module system some values were returning incorrect values or the value could be misinterpreted.
    - Logical Record not recording time position, not displaying counter accurately and Layer Logical Record not recording with Logical Record and hide/show of layers.
    - Invert Output, Add Output colors and Trace not rendering when using a large Clip in Advanced Output.
    - Double clicking on module icons, pressing command + Q on launch causing modul8 to crash.
    - Search for missing files could produce memory leak.
    - In some instances QuickTime movies in photo-jpeg codec could cause crashes.
    - In modules using drawView, fillrect not erasing and filled canvas with color causing color to invert.
    Freeframes plugins are now searched in:
    "directory of Modul8"/Plug-Ins
    /Library/Application Support/FreeFrame
    ~/Library/Graphics/FreeFrame Plug-Ins
    If you have not received a message directly from us and would like to participate in the Beta release please contact me at support [at] garagecube [dot] com and I will provide you with the info for downloading it.
    Your feedback is very valuable to us. If you find a problem please send contact support [at] garagecube [dot] com with your serial number, a clearly outlined description of the problem, your system profile and your crash logs if they are available.
    A section of the forum has also been created for sharing your feedback with the community.
    Happy testing!
    Kind regards,
    Modul8 Team
    gmint
    by gmint » Mon Sep 14, 2009 8:32 pm
    OMFG!
    DMX CONTROL. FTW.
    Stunned. Really, that's about all I can say at this point. STUNNED.
    DJ G Mint
    haye
    by haye » Mon Sep 14, 2009 8:56 pm
    aaaah great, now our weird minds have some new corridors to explore eh?
    congratulations. modul8 is alive!
    zava
    by zava » Mon Sep 14, 2009 10:50 pm
    Great, I'm testing :) on Snow Leopard.
    A lot of new features, thank you
    :::: zava ::::
    :::: Vjcentral.it ::::
    :::: vimeo ::::
    by The Midi Thief » Mon Sep 14, 2009 10:51 pm
    I just RVSP:ed to a party in my MBP!
    javier milara
    by javier milara » Tue Sep 15, 2009 12:50 am
    Terrific!!
    Works like a charm on 10.6, at least by now!
    Great update!
    M8 rocks and u r the best! :twisted:
    Gracias!
    sadcrew
    by sadcrew » Tue Sep 15, 2009 9:25 am
    Really great upgrade!
    The blending mode open a new universe for the compositing of any animations!
    I noticed M8 is getting faster on Snow. Everything is really accurate now.
    Maybe on little thing, the Wacom setting make the paint module even better, why not installing the pressure button on pen instead of point?
    Thanks for your work, we waited for that but now I can see how much you finetuned the whole software!!
    Bravo!
    SAD
    sadcrew
    by sadcrew » Tue Sep 15, 2009 9:42 am
    Bravo!
    SAD
  • snt
    by snt » Tue Sep 15, 2009 9:49 am
    Great upgrade guys!
    Just out of curiosity: what would the Modul8's Add and Substract blending modes be called in Photoshop? I take Add is the same as "Linear Dodge" but how about Sub? I don't think it's "Multiply".
    Here's an Adobe page for reference:
    http://help.adobe.com/en_US/PhotoshopEl ... 834DB.html
  • idolum
    by idolum » Mon Sep 21, 2009 4:29 am
    where can download the bate 2.6,i want to test,and test can do the chinene version!!
    thank
    by sigmasix » Mon Sep 21, 2009 8:49 am
    send an email to support at garagecube dot com with your serial number.
    pls
    beta running out..
    by pls » Mon Sep 28, 2009 5:52 pm
    as the modul8 2.6 beta is running out the next days i'm wondering if we get another beta running longer or if the new version will be available for upgrade?
    by ilan » Mon Sep 28, 2009 8:16 pm
    We are at this very moment trying to get beta2 out to all the current testers. We would not dare leave you hanging like that.
  • anomad
    by anomad » Tue Sep 29, 2009 4:28 am
    . yes please on letting us work more w/the beta!!!
    . i've almost got sound -> DMX lighting running flawlessly! :D
    . i'm really hoping the final release is ready by Nov 6th - i'm planning on using most of the new features for a rave!
    by boris » Thu Oct 01, 2009 6:07 pm
    I closed this thread. Please use the new forum related to the beta 2.6:
    http://www.garagecube.com/forum/viewforum.php?f=18
    Beta 2 has been released. You can find more informations in the new forum.
    Best,
    Boris.
