Modul8 V2.0.1 Available Now
    yves@garagecube
    by yves@garagecube » Fri Jul 08, 2005 2:59 am
    Modul8 V2.0.1 has been released
    Changes
    - Preferences: Added a settings for the global ram usage for Modul8.
    - Preferences: Added a preload memory size limit for project loading.
    - Preferences: Added video capture framerate settings.
    - Preferences: "Ignore sound channel" option is back.
    - Added a function to update your email in the GarageCube registration database from the inside of the application.
    - Added an update mechanism to download new version of Modul8 from the inside of the application.
    - Writing text in a text field does not activate keyboard shortcut anymore.
    - The media preview in the module are correctly scaled now.
    - Fixed slow down problem when opening a project.
    - Fixed a problem when loading a project which may cause all the storage mode to be set to stream.
    - Loading a project saved with the V2.0.0 causes the storage mode to be recalculated.
    - Improved full preload loading speed.
    - Improved the memory management.
    - Modul8 is more adaptive when trying to preload movies with a non constant frame rate.
    - Modules: Added missing feedback for ctrl_layer_activated keyword.
    - Modules: Added missing feedback for ctrl_master_layerFocusPosition keyword.
    - Modules: Added direct_soundCaptureLevel keyword.
    - Modules: -1 on ctrl_layer_media keyword, remove the media.
    - Modules: lightness key renamed to brightness to be conform with the UI.
    - Fixed an issue with text recording.
    - Text field background is lighter.
    - Many other optimizations and small bugs fixed.
    Modul8 users will receive an email with download information.
    Best Regards,
    The GarageCUBE Team.
    cal6n
    by cal6n » Fri Jul 08, 2005 4:16 am
    Thanks Guys. I look forward to checking it out.
    chromafresh
    by chromafresh » Fri Jul 08, 2005 4:58 am
    Thanks!! I tried it out for a sec and ran into my problem again after a few minutes... I'm starting to wonder if its not a problem on my side after all.
    Generally things seemed faster and more responsive up until the problem surfaced and it didn't feel bogged down up until my problem occured. As my partner also had a similar problem before and no one has reported being frozen out of their interface, I'm starting to wonder if its not something to do with a Japanese or 2-byte compatible system problem or something. I'll try it out again ASAP when I have a few moments. Thanks in the meantime!
    yves@garagecube
    by yves@garagecube » Fri Jul 08, 2005 10:50 am
    We did a lot of testing with this version and we were not able to reproduce this problem. You may also try to run it with the activity monitor and watch the memory/cpu usage. It would be intersting to know if Modul8 is still running or if it is simply frozen (CPU % for Modul8).
    It could be be a problem only on 2 bytes system... Do you use the text field ? We already had some problem with unicode and QT in the past. I'll try to do some tests with a japanase account to see if I can reproduce it.
    Jesper Fryd
    by Jesper Fryd » Fri Jul 08, 2005 11:32 am
    i didn't get an e-mail :?
    not to worry?
    yves@garagecube
    by yves@garagecube » Fri Jul 08, 2005 12:43 pm
    support[at]garagecube.com is your friend.
    The good news is that the V2.0.1 has an integrated updater... So we won't have to deal anymore with all these email troubles (junk mail filters, email not updated, typo in the email subscription...) for future releases.
    Jesper Fryd
    by Jesper Fryd » Fri Jul 08, 2005 1:04 pm
    it's not in my junk folder, and you have my correct address...?
    anyway, I sent you an e-mail. hope that sorts it :)
    Jesper Fryd
    by Jesper Fryd » Sat Jul 09, 2005 10:29 am
    still no mail here :( :?:
    VJFranzK
    by VJFranzK » Mon Jul 11, 2005 6:31 am
    performance MUCH better while loading - thanks! :D
    by boris » Mon Jul 11, 2005 6:42 am
    Please be patient, we can take a weekend break from time to time ! :shock:
    I sent you the download informations. :wink:
    Jesper Fryd
    by Jesper Fryd » Mon Jul 11, 2005 9:35 am
    Definetly not! :D
    Thanks for the link.
    Will post observations asap...
