Vibrator and text, new Modules.
    by boris » Fri Jul 08, 2005 6:01 am
    I put one new module on the online library (named Vibrator).
    It move all layers into your composition at the same time.
    You can use it to make several effects like trembling, random positions, etc...
    You can use x y z positions, level and speed parameters.
    Also I put a small update of the text module (text 1.1)
    Size and font is now 'contextual'
    chromafresh
    by chromafresh » Fri Jul 08, 2005 8:14 pm
    vibrator is nice. the trigger implimentation is good. yay for modules!
  • Akira
    by Akira » Sat Jul 09, 2005 10:12 pm
    Some thing I notice in MOST modules...
    when you stop them (hitting the PAUSE buitton) the layer properties are not restored to the state where they were before using the module in teh layer. this is a bit annoying since there is no way to snap back to previous settings!
    by boris » Mon Jul 11, 2005 3:34 am
    If you want this, is it possible.
    Use the pauseEvent script (into the module) for this.
  • Akira
    by Akira » Tue Jul 19, 2005 11:45 pm
    That will restore the previous settings? I'll try.
