anyone use VGA extenders for projectors 400 ft (120m) away
  • JJHP3
    by JJHP3 » Sun Sep 20, 2009 5:45 pm
    Hi Folks
    Working on a proposal for a video projection outdoors. Source cameras and a laptop running M8 about 400 feet from projectors. Looking into good quality VGA extenders (Geffen, Lindy, etc) which seem like they would work... any experiences or suggestions to share?
    Much appreciated,
    John
    by vanakaru » Sun Sep 20, 2009 7:21 pm
  • JJHP3
    by JJHP3 » Sun Sep 20, 2009 8:51 pm
    Thanks - I'm already onto VGA / CAT5e send/receive units - have you had any experience with 400 foot runs? They would terminate in 16k+ Barco projectors.
    Thanks
    John
    by vanakaru » Sun Sep 20, 2009 10:02 pm
    I have used 100m runs without a problem no amplifier. I have a Gefen baluns - not too expensive, but are used by many our projector rental companies. Their cat5 cable comes usually in 200-300m drums adapters built in the drum. We have used in high pro setups flawlessly.
  • zangeena
    by zangeena » Wed Oct 07, 2009 9:24 am
    How do I get the best out of my mini vga to hdtv? I'm buying a mini vga to VGA adapter and run the vga to my hdtv as it has a vga input. I have a 32" Samsung TV. Once connected do I need to change any settings on my TV or iMac G5 (Leopard) to make the outcome look the best it can?
    And how do I do so on my mac?
    __________________
    yahoo keyword tool ~ overture ~ traffic estimator ~ adwords traffic estimator
  • mowgli_uk
    by mowgli_uk » Wed Oct 07, 2009 3:49 pm
    Is your tv 400 feet from your iMac?
  • vj_ava
    by vj_ava » Wed Oct 07, 2009 8:49 pm
    Thanks
    John
    I know a guy doing 500ft throws at times using cat, you should be good, just make sure to amplify the signal.
    deepvisual
    by deepvisual » Thu Oct 08, 2009 8:53 am
    you can only use lower resolutions over longer distances.
  • traitdelumiere
    long distances
    by traitdelumiere » Thu Oct 08, 2009 6:21 pm
    I already used an ethernet system for a show.
    4 x 12000 lumens projectors synchronized and about 80m of cable for each of them.
    The solution is simple :
    4 VGA to ethernet converters connected to the computer
    + 4 ethernet to VGA converters connected to the videoprojectors
    In an other show, we used 400m of optic fiber between 2 pcs it's a good solution but very expensive…
