frame blending
  • chriss0212
    frame blending
    by chriss0212 » Mon Oct 05, 2009 4:10 pm
    does module8 support frame blending?? problem is a mix aof 25 and 30 fps loops and my monitor is running on 60fps and so with 25 fps loops they are jerking....frame blendig whoul avoid this
    greetz
    chriss
    nestor
    by nestor » Mon Oct 05, 2009 10:59 pm
    Try deinterlace
  • chriss0212
    by chriss0212 » Tue Oct 06, 2009 12:29 am
    hi nestor
    why deinterlaceßß the videos are already progresiv but with a framrate of 25 fps but the display is running on 60 fps so the renderer has to render more then twice but it is a factor of 2.something and this is only with interpolation possible but realtime renderer cant do that interpolation so that they hav to repeat the frames mostly twice but sometime 3 times and this 3 times make it look jerky. bur maybe i am wrong and interlacing is the trick :-) can i do that inside module8 ore do i have to rerender?
    thx and greetz
    chriss
