shares from other module.
  • diez54
    by diez54 » Tue Oct 06, 2009 4:22 am
    I try to put a little script to automate some of my actions.
    It's quite affordable, with the visual interface.
    But I blocked on a problem I want to use shares from
    other module.
    I would like to create a button to apply an effect on multiple layers, for example,the "enabeld" off FILTER's module or the "ON" off "random CROP's module
    How? thx
    Diez
  • diez54
    by diez54 » Tue Oct 06, 2009 8:43 pm
    anyone have an answer?
    by ilan » Tue Oct 06, 2009 8:58 pm
    To answer your question... if I understand it correctly... it is not at the moment possible to send data from one module to another.
  • diez54
    by diez54 » Tue Oct 06, 2009 9:24 pm
    It is not possible to apply simultaneously an effect (ofa module) to several layers... It's a probleme for me.
    Perhaps in future version
    thanks for this answer..
    by The Midi Thief » Wed Oct 07, 2009 6:40 am
    That is depending on each modulue. Some modules are layer contextual, meaning you can apply the module to any layer and several layers at the same time but you have to mark each layer in the main interface and then set the values in the module for each layer.
    Some other modules has 10 layer buttons, one for each layer to affect.
    You always have the option of modifying modules to work in a way you want if you have some basic Python skills. In that way you can also make modules listen to each other. Like the some modules listen to the BPM (global) module, for instance.
