Probleme with Flash and invert
  • diez54
    by diez54 » Wed Oct 07, 2009 5:34 pm
    I have a problem when using the flash and the invert, they do not apply
    entire screen, two black bands result does not change the top and bottom.
    I put a picture or invert is applied on a totally black screen, it should
    become completely white .... (see attach pictures)
    I live to do a Friday night and it bothers me a lot.
    I have already tried to disable all the modules, Thanks.
    Ps: I don't now for why image balise don't work ...
    by The Midi Thief » Wed Oct 07, 2009 10:07 pm
    Have you tried the Epileptic Strobe module for flash? For the invert I can't help, unfortunately.
  • diez54
    by diez54 » Wed Oct 07, 2009 11:04 pm
    It's the same with epyleptic strob modul...
  • diez54
    by diez54 » Wed Oct 07, 2009 11:17 pm
    I've find reason of my probleme:
    In output setup if my clip size is below 640*480 no probleme (no black bands)
    If my clip size is over to 640*480 I have this two black bands ....
    And I want a clip size of 800*600 ...
    Someone can help me ?
    deepvisual
    by deepvisual » Thu Oct 08, 2009 8:52 am
    turn off advanced output setup.
    you don't need it unless you are using a mac tower
  • diez54
    by diez54 » Thu Oct 08, 2009 4:46 pm
    ok, I understand now , thanks for your reply
