recording vjset in modul8?
  • noizester
    by noizester » Mon Oct 12, 2009 2:23 pm
    hi there!i want to record an 1 and 1/2 hour set that i want to copy on dvd
    is it possible with the recording mode of modul8 or i have to do it another way?i need a quick response
    thanx
    VjKg
    by VjKg » Tue Oct 13, 2009 1:58 am
    Quick answer=yes
    Long Answer= Well, maybe
    Much easier to record Analog output to different device, but depending on your setup it can be done on your computer.
  • Digitalcargo
    by Digitalcargo » Fri Oct 16, 2009 9:54 pm
    Use Logical Record!
    Just hit the red record button on the Logical Record interface (lower right-hand corner), and then you can render it out at your convenience after the show.
    That means you can deal with any issues (file size, etc...) later, and not have to hassle with it during your show.
    DC
