Thanks! I'll install a PCI card into my Macbook then - which is also a 1st generation machine.
I may be wrong, but I would not try anything HD on 1st gen. MacBook. I doubt it will even play full HD movie in Quicktime without drop outs.
Macbooks are designed for light use and specially have poor video cards with little VRAM. To have these things at the maximum will make Modul8 so powerful and stable.
And you can not install anything INTO your Macbook(except HDD and RAM). The only option is use external devices and mentioned by VjKg, but PCI box with video cards and eSATA Express card to your mac will cost as much your MB.
But you should try, before upgrading your system what you can run successfully. And be creative about the content instead. Like you can run simple graphics (PNG) files with lots of effects to very high resolutions.
