. question about auto fx...
  • anomad
    by anomad » Thu Oct 22, 2009 2:17 am
    . is there a way to read the various values of ctrl_layer_auto_????? functions? i know you can turn it on and off, change the modulation source and look at the speed.
    . for example, can i get the RGB values in Auto Color that it's using to modify the video?
    . can I get the xy position of the Auto Move ?
    . i'm playing around w/changing the intensity of some midi->multiplex lights and wanted to sych them with the values of the auto RGB values
    . then i was going to try to have some fx modules respond to the result of the auto modules.
    . any ideas? or am i barking up the wrong tree?
    . thx!
    -james
    (a nomad. )
