Custom midi controllers.. need some help figuring this out
  • mannikin
    by mannikin » Tue Jul 12, 2005 2:13 am
    First off, thank you garageCUBE! Did my first show saturday night using Modul8 and it was simply brilliant. :)
    I'm currenly using a microkontrol as my mid controller. I am planning on building some customer midi triggers (pipes, plastic sheets, etc...). I was curious if anyone else is using custom triggers, and my main question is how does one hook up these triggers to be used with Modul8?? What sort of hardware would I need? I would love to figure this out, so I can really make my shows super interactive. Appreciate any info.
    Thanks;
    John
    S Y N F O N Y<> S T U D I O S
    powerbook G4 15"
    Tiger / 2GB RAM
    Korg microKontrol
    modul8 V2
    http://www.synfony.com
  • mannikin
    Re: Custom midi controllers.. need some help figuring this o
    by mannikin » Tue Jul 12, 2005 7:08 pm
    Any midi gurus out there that can help me out here? :wink:
    J.
    mannikin wrote:Hi,
    Thanks;
    John
    powerbook G4 15"
    Tiger / 2GB RAM
    Korg microKontrol
    modul8 V2
  • jm302
    by jm302 » Tue Jul 12, 2005 8:22 pm
    mannikin wrote:Any midi gurus out there that can help me out here? :wink:
    J.
    I've never tried this myself, but my band is looking into syncing a drummer with the laptops. I found a company called Circular Logic (http://www.circular-logic.com/) who makes software for doing just that. They have(or did have in the past) detailed instructions for setting this up on their website. I believe you'll find all the info you need there...
    Cheers,
    Justin
    http://www.302acid.com
  • mannikin
    by mannikin » Tue Jul 12, 2005 8:53 pm
    Thanks Justin. Will definitely check it out.
    J.
    J.
    Cheers,
    Justin
    powerbook G4 15"
    Tiger / 2GB RAM
    Korg microKontrol
    modul8 V2
  • Mandingo
    by Mandingo » Wed Jul 13, 2005 12:59 am
    If you have some soldering skills. This is the place to check out.
    www.ucapps.de
    by boris » Sat Jul 16, 2005 3:21 pm
  • JJHP3
    RE: custom midi controllers..help
    by JJHP3 » Sun Jul 17, 2005 1:30 pm
    The cheap $150US MidiTron by Eric Singer works great for analog sensors into midi. Comes with a max-based chip programming program.
    http://eroktronix.com/index.html
    John
  • Guest
    Yes!
    by Guest » Mon Oct 03, 2005 12:16 pm
    I could not agree with you more.
