Cannot save project
  • zimp
    Cannot save project
    by zimp » Sun Oct 25, 2009 6:52 pm
    Hey,
    I am new to using modul8 so I don't know all of the technical words around the program or VJing in general, so please be specific.
    When I am done working on a project and try to save it, I am not able to do so. I have tried saving in folders I have full ownership of, but no file will show up after I click save.
    I am running Snow Leopard on a MacBook Pro 13".
    In other posts with people not able to save they are told to disable all of the modules. What does that mean and how can I do it?
    Thanks for helping
    by vanakaru » Sun Oct 25, 2009 11:10 pm
    MBP and SL: saving works fine. What modules you have open? And what version M8 you use (beta, demo etc.)
  • zimp
    by zimp » Mon Oct 26, 2009 2:34 am
    Running Modul8 2.58
    by ilan » Mon Oct 26, 2009 12:39 pm
    We're you running a cracked version of modul8 before you bought your license?
  • mowgli_uk
    by mowgli_uk » Thu Oct 29, 2009 1:34 pm
    tumbleweed flies by...
    by ilan » Thu Oct 29, 2009 2:06 pm
    On that theme... I will not pull out my six shooters at you if you did.
    What you need to do is:
    1 - Deauthorize the full version.
    2 - Launch the cracked version.
    3 - Deauthorize the crakced version.
    4 - Launch the full version and authorize it.
    If that does not work contact support we'll reset the account.
