module Editor_Inserting Text
  • FadiBanat
    by FadiBanat » Thu Oct 29, 2009 12:54 am
    Need your help to create a module for inserting text in a layer
  • martyw79
    TEXT Module
    by martyw79 » Thu Oct 29, 2009 4:42 am
    There's already a module to insert text as a layer.
    Check the modules I believe it's called TEXT.
    VjKg
    by VjKg » Fri Oct 30, 2009 2:50 am
    I really wanted to post that info but I thought I was missing something in the parent.
  • FadiBanat
    by FadiBanat » Sat Oct 31, 2009 1:34 am
    I checked but there is nothing under modules tab called text,,,,
    I would really appreciate receiving a healing answer for this.
    Thanks
    by ilan » Sat Oct 31, 2009 2:46 am
    It ships with Modul8 pre-installed.
    From the finder menu select:
    Modules > Show > TEXT
    If you accidentally removed it from you Modul8 folder then select:
    Modules > Online Library
    - Click on the GarageCube Library tab
    - In the search field on the upper right side of this this window type in 'TEXT'
    - On the bottom of the window click on 'Install'
    - Quit Modul8 and when prompted hit 'Save'
    - Launch modul8 and then repeat the procedure above
    If you do not see any modules when you select 'Show' then check to see if there is a modules folder in the folder where Modul8 is.
    If it is there and you still do not see the modules when using the 'show' menu then something else is terribly wrong and you need to send a message to support at garagecube dot com.
    Please provide us with your serial number so we can verify your account with us.
  • FadiBanat
    by FadiBanat » Sun Nov 01, 2009 12:31 am
    Great Ilan !!!
    It's working now. Thanks for the help
    by ilan » Sun Nov 01, 2009 1:13 am
    My pleasure.
    Also check out some of the other text related modules. The most useful one IMHO is (vs) Text Changer (layer) that allows you to load in several pieces of text and play them back.
