problem with the scale
  • bal
    by bal » Sat Nov 21, 2009 8:15 pm
    hi i dont know why this happens but its starting to freaking me out, and i cant find how to fix it , i have the most actualized version and deinstalling and reinstalling doesnt have done anything, the scale parammeter its alwais at the middle, its like if i have a layer with the scale at 1/4 and i duplicate it it appears with the scale at the middle , or if i have different layer with different scale values and i save the proyect when i reopen it the values of all the layers appear at the middle of the bar. i have also turn off all the modules i have on it installed but the problem doesnt comes from there neither any one with an idea of what could i do?
    by ilan » Sun Nov 22, 2009 7:32 pm
    Hello bal,
    Are you using Modul8 2.5.8 or Modul8 2.6 RC1?
    As shown here the scale slider is always by default in the center.
    From what I understand in your writing is that when you:
    1 - Change the scale size.
    2 - Save a project file.
    3 - Quite Modul8.
    4 - Open the project file you just saved.
    The result is that the setting of the scale of the layer is centered and not what you set it to?
    I have just run a test using Modul8 2.5.8.
    1 - Created 5 layers.
    2 - Assigned 1 media to each layer (I only used 1 media in the project).
    3 - Scaled each layer differently.
    4 - Saved the project.
    5 - Quit Modul8.
    6 - Launched Modul8.
    7 - Opened the project file.
    The result was that all of the scale values remained as I had created them. So I am not able to reproduce the problem.
    Can you provide me with an outline as to how I can try to reproduce the problem?[/img]
