New to modul8 from arkaos and having ISSUES
  • djmiguelg
    by djmiguelg » Tue Dec 01, 2009 2:02 am
    ok guys i have 2 problems and im hoping i can get it fixed. im using version 2.5 by the way.
    1. how can i set modul8 to go through random media clips(my case flyers) without it going to an empty media clip. if i have all the flyer jps in page one then how can it be set to be random in that page and skip the empty slots..
    2. all my media are different sizes... is there a way to auto size or scale the media clips so they fills the entire output screen? maybe there is a setting i overlooked
  • camil
    by camil » Tue Dec 01, 2009 2:20 am
    1. Download the module named (vs)Media Sequencer from online library.
    Or , to avoid empty media boxes, can use Slide Show module.
    2. In transform panel is a checkbox named "Normalize".if you check this box all media will be scaled to output resolution.
