Problem m8 2.6
  • Jellyfish
    Problem m8 2.6
    by Jellyfish » Mon Dec 07, 2009 10:25 pm
    Hi there, i've a problem with the last version of m8.. when i save a new project, and then i try to open it,
    a windows with this message appears " this version 2.6 beta has expired.."..
    but really i'm running the new version, not the old beta...so if i drag the icon
    of the project that i've saved into the application it runs...but the layer doesn't work...sorry but i'm in trouble...
    thanks for your help....
    by ilan » Tue Dec 08, 2009 11:28 am
    You are sure you completely removed the Beta and the Release Candidate from the computer? Just to be sure double check your applications directory.
  • Jellyfish
    by Jellyfish » Tue Dec 08, 2009 3:47 pm
    Hei ilan thanks for your help...effectively i forgot some part of the old version in
    my application folder..now it works perfectly..
    ..very good job the latest version..
    cheers____J_______
    by ilan » Tue Dec 08, 2009 7:11 pm
    Excellent. Thank you for the confirmation.
