layers resetting when i reload
  • infectedspleen
    by infectedspleen » Mon Dec 14, 2009 3:38 pm
    hay all,
    i have upgraded to the new 2.6 running on a mac book pro osx 10.5, and every time i create a new project and set the scale/posistion of my layers, i then save the file.
    when i reload the project, all my layers have rest them selves back to the center of the comp. this is very strange and with using modul8 in the theatre alot, this can have major problems for me.
    i know that older versions did not do this and am wondering if anyone else has had this problem and is there any way round it, i would not like to go back to an older version, becasue i am taking full advantage of the DMX controll, which has made my job a lot easyer.
    thank you in advance
    jason
    infectedspleen
  • afreemind
    by afreemind » Mon Dec 14, 2009 4:46 pm
    you have to ckeck your active modules.
    some moduls set your layers back.
    deactivate the modules one by one and you will see wich one makes trouble.
  • infectedspleen
    by infectedspleen » Wed Dec 16, 2009 1:54 am
    thanks afreemind,
    that seemed to do the trick, i've not found out which module is resetting my layers, but deactivating all of them for now works.
    thank you
