Life HD feed
  • modul_scorpio
    Life HD feed
    by modul_scorpio » Mon Dec 21, 2009 10:12 pm
    Hello everyone.
    I've been using Modul8 with prerecorded/edited material from my HD camcorder, but lately I've been wondering if I can use my camcorder for live feed somewhere in the middle of my edited material.
    The thing is that I am using the newest Sony HD Handycam which comes with a USB cord but is not being detected by Modul8.
    Any ideas?
    david
    by david » Wed Dec 23, 2009 6:08 pm
    Hello modul_scorpio,
    most (if not all) these USB camcorders records in AVCHD locally, and they does not send any data on the USB bus live. You usually record locally on the camcorder (flash or HDD) and THEN transfer the file to the host (PC/Mac).
    I could be wrong, but if someone saw one of these USB camcorder delivering live feed, we would be glad to know.
    Regards.
  • martyw79
    no can do
    by martyw79 » Mon May 10, 2010 7:40 am
    Unfortunately David's right...those AVCHD cameras don't allow live feeds via USB. I have one too any now need some cheap solution to getting a live feed for bands performances. Thought of a webcam but not too sure what the quality would look like.
    by sigmasix » Mon May 10, 2010 8:22 am
    your only solution if you want to use your AVCHD camera is to stream using the HDMI cable and use a capture card to get the feed into modul8. On a macpro, I think the best solution is the blackmagic intensity, but there are other cards, and some you can also use on your macbook pro.
    by The Midi Thief » Mon May 10, 2010 5:47 pm
    I researched this with getting a HD signal in to the camera last week.
    The AJA Io HD lets you grab video and transfer it to a Macbook Pro using Firewire 800. The AJA io Express lets you transfer to a Macbook Pro using an ExpressCard*. http://www.aja.com/products/io/io-hd.php
    The HDX-SDI from Motu also seems to be able to cabpture HDMI. You can connect it to a laptop with an ExpressCard*. http://www.motu.com/video-products/hdx-sdi/body.html
    The Mx02 from Matrox is probably the cheapest solution (?) for getting HD video in to your computer live. I think Vade did a test with this unit. The latency is pretty low.
    http://www.matrox.com/video/en/products ... mxo2_mini/
    * Only the 17" inch MBP models has the ExpressCard slot on the last two MBP models. Vade pointed out (in the above mentioned test) a backside of having a unit that plugs in to the Express Card slot. If you accidently bump the Express Card during a gig it pops out and you may have to restart your software or reboot the computer to regain the video signal.
