midi toggle on/off?
  • pixel8
    midi toggle on/off?
    by pixel8 » Tue Dec 29, 2009 5:05 pm
    Hi all,
    Is there some way to send a midi signal to toggle a layer on/off? By this I mean tapping to trigger either an on or off state. (instead of having to hold the key down?
    Thx
    by sigmasix » Tue Dec 29, 2009 5:44 pm
    this depends on your controller, some buttons are toggle, others are continuous. You can trick modul8 by making a module that check the state of your layer before applying either on or off. then you map your midi to the module and not the layers
  • janzak
    by janzak » Sun May 02, 2010 7:54 pm
    sigma6 wrote:this depends on your controller, some buttons are toggle, others are continuous. You can trick modul8 by making a module that check the state of your layer before applying either on or off. then you map your midi to the module and not the layers
    Yo! How would you do that more specifically? I've no idea how modules are constructed...
  • mowgli_uk
    by mowgli_uk » Mon May 10, 2010 1:34 pm
    read the documentation
