PLEASE GARAGE CUBE PIMPS MY M8
  • mogeny sylvain
    by mogeny sylvain » Thu Dec 31, 2009 4:39 pm
    HELLO,
    i AM just went to convert to modul8 before i work on arkaos.
    i need larsen effect .
    somebody can help me.
    by sigmasix » Thu Dec 31, 2009 5:27 pm
    what are you calling a larsen effect? do you have an example?
  • mogeny sylvain
    by mogeny sylvain » Sun Jan 03, 2010 4:24 am
    c'est un bouclage du signal vidéo, l'image va se répéter dans l'image a l'infini. Exemple simple avec une camera relier a un moniteur, tu cadres ton moniteur et tu as un larsen vidéo.
    J'aimerais un module ou il est possible d'activer et désactiver le bouclage. de pouvoir scaler et positionner et faire les rotation. et la cerise sur le gateau un potar trace indépandent du masteur trace. je suis sur que ce n'est pas compliquer pour quelqu'un qui parle bien le python.
  • janine
    by janine » Sun Jan 03, 2010 7:21 pm
    i think you mean a feedback effect.
    it would be realy great to implement it in module8 !
    a good inspiration could be the feedback implemention at the resolume software. there you can choose the feedback from the source menue.
  • mogeny sylvain
    by mogeny sylvain » Sun Jan 03, 2010 9:57 pm
    EXACTLY Janine
    I love play with feedback effect on twin layer and so mutch other effect. I will try resolume. but I have buy modul8 AND I WANT TO USE IT. do you think it possible to create modul feed back?
    by ilan » Sun Jan 03, 2010 10:00 pm
    These guys have a feedback filter using FreeFrame that works very nicely in Modul8.
    http://vjfx.com/
  • janine
    by janine » Mon Jan 04, 2010 4:35 pm
    thanks for the tip ilan !
    but it would be great, if we had a build in
    openGL accerlerated feedback which works on all
    underlaying layers.
    this would also be much faster !
    by ilan » Mon Jan 04, 2010 4:38 pm
    For the record FreeFrame is OpenGL accelerated.
    As for having the feedback affect underlying layers, that is probably a much more complex process considering the current architecture of modul8.
  • mogeny sylvain
    by mogeny sylvain » Tue Jan 05, 2010 11:31 am
    http://vjfx.com/
    Hi Ilan,
    thanks for the link free frame , i have ever work with their plug ins long time ago. they have lot of plugs and application. Do you know what i must be download for mac platform?
  • vj titan
    by vj titan » Wed Jan 06, 2010 5:49 pm
    Hi all,
    I have tested these plugins half a year ago.
    They have a very poor quality.
    They always stutter, if you use it with modul8.
    If you want to play smooth clips, it will not work for you.
    My system was: Macbook Pro, 2,16 intel core 2 duo
    with one Clip (768x576, PhotoJpeg 75%) and 1 vjfx effect.
    Best,
    T.
    by ilan » Wed Jan 06, 2010 5:58 pm
    A review of all of these FX and their compatibility:
    http://www.garagecube.com/forum/viewtopic.php?t=4582
    Big kudos to . nomad for putting this list together.
