sound analysis does not work
  • sitosun
    by sitosun » Tue Jan 05, 2010 2:20 am
    hello!
    i got a weird problem with 2.6 rc1 - that the sound analysis does not show the low mid and high level. instead of the green level-bars there is only empty white space.
    anyone got the same problem?
    (audio input works properly)
    also animation fx does not react on these bands - only "sound level" seems to work.
    it all worked fine on the beta versions by the way.
    thx,
    sito
    by ilan » Tue Jan 05, 2010 10:40 am
    Hello Sito,
    RC 1 expired in November.
    And the final release 2.6? Is that working ok? If you do not have it or are having trouble getting it please contact me via support.
  • sitosun
    by sitosun » Tue Jan 05, 2010 8:01 pm
    hi ilan!
    yes you're right .. i posted the wrong version .. i meant the final release modul8v26 1007
    rc1 worked fine.
    however today i tried again many times and somehow suddenly it worked again.
    dont know why ..
    so .. everything allright ;)
    by ilan » Wed Jan 06, 2010 1:19 pm
    Thanks for the clarification. Sometimes its just a matter of remembering to turn the volume up on the input. Happens to me once and a while.
