. Free Frame intrinsicFX (vjfx.com) and Modul8 v2.6 test
  • anomad
    by anomad » Tue Jan 05, 2010 6:42 am
    . after spending too much time wondering what effects from vjfx.com would actually work on a mac w/modul8 - if they'd work at all - i decided to scrape up my vj tip money and buy the full IntrinsicFX pacakage. (and they were on sale, so that helped too! )
    . edit to add - i bought the Mac versions, not PC (in case that wasn't clear)
    . i just spent the last 4 hours experimenting with the effects and here are my results (running Modul8 v2.6 on a MacPro OS X 10.6.2 ) note: i probably spent ~5 minutes w/each effect -- so while not an exhaustive test, i believe all effects that are listed as working to be stable
    IntrinsicFX - Modul8 v2.6 tests
    IntrinsicFX_CollectionX_2.0
    - A mixed bag of working, not working and do not load...
    IscEchoLight1_ub.frf ! crashes Modul8
    IscFluid1BW_ub.frf ! crashes Modul8
    IscFluid1_ub.frf ! crashes Modul8
    IscGlow1_ub.frf works
    IscGlow2_ub.frf works
    IscGlow3_ub.frf works
    IscLightGrow1_ub.frf works
    IscMICrop1_ub.frf does not load in modul8
    IscMIDisplace1_ub.frf does not load in modul8
    IscMIRefColors1_ub.frf does not load in modul8
    IscMIRefDelay1_ub.frf does not load in modul8
    IscMIReflection1_ub.frf does not load in modul8
    IscMISmoknEdges1_ub.frf does not load in modul8
    IscMotionFade1_ub.frf works
    IscMotionFade2_ub.frf works
    IscPaint1_ub.frf ! crashes Modul8
    IscRefleColors1_ub.frf works
    IscRefleDelay1_ub.frf works
    IscReflection1_ub.frf works
    IscTileCircles1_ub.frf works
    IscTileCircles2_ub.frf works
    IscTileCircles3_ub.frf works
    IscTileDelay1_ub.frf works
    IntrinsicFX_Colmatic_2.0
    - All plugins work
    IntrinsicFX_CrossFadeWipe_2.0
    - Plugins do not load into Modul8, but that makes sense b/c they're designed to use two inputs and fade between them
    IntrinsicFX_CrossFadeWipe_2.0_1InputSupport
    - All plugins work, but since they're transitions to themselves they're not very interesting...
    IntrinsicFX_Deformations_2.0
    - All plugins work
    IntrinsicFX_Frames&Flow_2.0
    - All plugins work, except
    IscTile3DInv1_ub.frf works but using Zoom3D crashes Modul8
    IntrinsicFX_MixWithInks_2.0
    - None of the plugins load into modul8
    IntrinsicFX_MixWithKeys_2.0
    IscKeyBumpMap1_ub.frf does not load in modul8
    IscKeyCellular1_ub.frf does not load in modul8
    IscKeyChroma1_ub.frf works
    IscKeyChroma2_ub.frf works
    IscKeyChroma3_ub.frf works
    IscKeyDifferenc1_ub.frf does not load in modul8
    IscKeyFoldsRGB1_ub.frf does not load in modul8
    IscKeyFoldsRGB2_ub.frf does not load in modul8
    IscKeyInvColBur1_ub.frf does not load in modul8
    IscKeyLuma1_ub.frf does not load in modul8
    IscKeyLumaRGB1_ub.frf does not load in modul8
    IscKeyStamp1_ub.frf does not load in modul8
    IscKeyXOR1_ub.frf does not load in modul8
    IntrinsicFX_OnTheEdge_2.0
    - All plugins work
    IntrinsicFX_PlasmaPlasma_2.0
    - All plugins work
    IntrinsicFX_Sparks&Flames_2.0
    - All plugins work
    IntrinsicFX_WaveBlur&Deform_2.0
    - All plugins work
    IntrinsicFX_WeirdFeeds_2.0
    - All plugins work
    . overall, i'm really pleased w/my purchase and say it's a great effort from Thomas @ vjfx.com - some of the effects included are absolutely stunning. i'm planning on coding some to audio input levels and making some test videos soon...
    -james
    (a nomad. )
