inside us all plugins
  • nikon
    by nikon » Tue Jan 05, 2010 10:07 pm
    hey
    i have a problem with IUA plugin custom hex, evry time when i triger clip hexs are in difrent positions. i was trying module8 2.6, 2.5.9 and if i find will probably try 2.5.8. can it be the OSX problem im on SNOW leopard or it is just freeframe plugin bug? do i need to put them in some other folder than app>module8>plug-ins ?
    here is the short movie that explain the problem, funny thing when rendering logical record from module8 problem shows only 2 times, in 7s and 26s, but when i was recording it evry time i changed clip hexs was in difrent possitions.
    http://www.youtube.com/watch?v=I36dtmtiRj8
    if someone can help me with this it would be great becouse i dont have money for addict server ;D and i realy want to make hex setup at my next partys ;)
    i emailed IUA about this but it take long time for them to answer.
  • nikon
    by nikon » Tue Jan 05, 2010 11:15 pm
    same problem on leopard and module8 2.5.9 can i have link to module8 2.5.8 ? to check it ?
    edit:
    ok looks like i found solution but i dont realy like it, all loops need to have same resolution and then it work 90% of time, but still it can crach module8 after some heavy loops trrigering.
    buyed single windows plugin from resolume homepage and tested it with reso clips can have difrrent resolution there is no crach or other unexpected shit. if you dont want to lose 75euros for mac version go win xp (hate windows) solution.
