4 Live Video Input...
  • videsad
    by videsad » Fri Jan 08, 2010 7:10 pm
    Hello
    Im working with M8 for a while. With the new Version it should be possible to connect 4 Cams.
    Im not realy sure wich hardware i need. I know there are posts in the forum. But they dont realy helping me.
    greets Patrick v/o videsad
    by vanakaru » Fri Jan 08, 2010 7:26 pm
    It is useful with MacPro with dedicated capture cards. With MBP I can get 4 video ins if I have 4 different capture devises like USB EasyCAP, XLR8, Quickcam and FireWire iSight. But you can not do much with this before you kill your CPU.
  • videsad
    Video in
    by videsad » Sat Jan 09, 2010 11:51 am
    Hello.
    Thank you for your post. I work with a mac pro.
    Can you give me a Example.
    I work with a pannasonic cam dv FireWire in.
    Input1:Dv FireWire
    but how can i connect Cam 2,3 & 4
  • anomad
    by anomad » Sat Jan 09, 2010 12:02 pm
    . get a sony ps3 eye camera .... it's usb and the quality is amazing for the price
    . use maccam (http://webcam-osx.sourceforge.net/ ) drivers to get it working...
    -james
    (a nomad. )
  • videsad
    Live Input
    by videsad » Sat Jan 09, 2010 12:53 pm
    Thanks.
    Can i use more than One of this Cam?
    Greets
    by vanakaru » Sat Jan 09, 2010 5:59 pm
    I would use Blackmagic (I have to ask what model our team live video guys are using) capture cards and analog cameras.
    At present I think you can get just one firewire input and that is DV encoded by default.
    Re: Live Input
    by vanakaru » Sat Jan 09, 2010 6:01 pm
    videsad wrote:Thanks.
    Greets
    All your input devices must be different models now.
  • videsad
    Live Video
    by videsad » Sun Jan 10, 2010 2:16 am
    Ok.
    So can i use two USB Cams, One dv Device over FireWire and
    One blackmagic capture Card.(there are many different Cards)
    Does this work? I Hope so.
    Greets videsad
    lotech
    by lotech » Sun Jan 10, 2010 2:45 am
    Yeah its a small problem with Modul8 that there isn't much documentation on the advanced stuff. I was about to ask a similar question do I didn't go wasting even more money on capture devices.
    Apparently VideoGlide does allow more than once instance of itself and allows for more capture devices - but I haven't checked it myself. I did start a video capture device thread so we could share our experiences - http://www.garagecube.com/forum/viewtopic.php?t=3951
  • VJnutcracker
    by VJnutcracker » Sun Jan 10, 2010 9:48 am
    Sometime this week i'll be testing a macbook pro with 4 videoglide usb devices, 2 via usb and 2 via an expresscard to usb adaptor.
    I will let you know the results.
  • anomad
    by anomad » Sun Jan 10, 2010 4:50 pm
    VJnutcracker wrote:Sometime this week i'll be testing a macbook pro with 4 videoglide usb devices, 2 via usb and 2 via an expresscard to usb adaptor.
    . cool! :) i've very interested to know how the expresscard adapter works out... which one are you using?
    -james
    (a nomad. )
  • videsad
    by videsad » Mon Jan 11, 2010 12:01 am
    :D
    great. im like to know about your results.
  • VJnutcracker
    by VJnutcracker » Wed Jan 13, 2010 4:53 pm
    anomad - it turns out to only have one usb socket and 2 firewire expresscard adaptor. (Card is Belkin Part no. FSU506).
    Ok i've spent a couple of hours messing about with 4 video glide dc60+ usb capture units and a 2006 macbook pro.
    1 USB Input - superb quality image, tested capture size up to 2048x1536 - no problems
    2 USB inputs - Works fine on both units , maximum capture size 360x288 on both.
    (reduced usb bandwidth setting to 50%)
    3 USB inputs - Works fine on all units, maximum capture size 360x288 on all
    (reduced usb bandwidth setting to 33%)
    4 Input (3 USB & 1 Expresscard USB adaptor) - Will only display 3 devices at once.
    (tried many different combinations of capture size/usb bandwidth settings)
    One of the 4 screens turns purple when not working, if another working device is unplugged the previously purple screen unit starts working, it does this when unplugging any input, usb or expresscard.
    4 Input (3 usb & 1 firewire) - Same result as above.
    4 input - (2 usb, 2 expresscard (using a powered usb hub to give enough sockets) - same results as above.
    Col
    lotech
    by lotech » Thu Jan 14, 2010 12:24 am
    It sounds like using mixed input devices is the best way to get more than one input. Thanks for the research, I won't be rushing out to buy more DC60+'s then. Even a single input with relatively good latency is good enough. .
  • anomad
    by anomad » Thu Jan 14, 2010 2:25 am
    VJnutcracker wrote:anomad - it turns out to only have one usb socket and 2 firewire expresscard adaptor. (Card is Belkin Part no. FSU506).
    . cool! and fantastic work on the list! i know how much time those things can take to do ! :)
    . i think i might pick up an APIOTEK EC-0011 ( http://eshop.macsales.com/item/Apiotek/EC0011/ ) and try at least two sony PS3 cams on that... time to save a little money.
    -james
    (a nomad. )
Users browsing this forum: No registered users and 59 guests
