V2.6 Transformer button bug?
  • LeavingSunday
    by LeavingSunday » Sun Jan 10, 2010 12:27 pm
    When I open a saved file (created in v2.6), the transformer functions aren't highlighted. It keeps the correct transformer settings: matrix, patch, particle and it's properties for each layer. But the transformer button is dimmed. So I have to toggle them all manually each time the project is opened.
    When the file is loading, I can see that the transformer button is highlighted. When finished loading all of a sudden it toggles to off?
    Anyone else experienced this?
    I am using a MBP & os10.6.2
    by boris » Sun Jan 10, 2010 1:22 pm
    This is weird...
    Did you try to stop all modules ? (menu Module->Stop all)
    It is maybe a Module conflict... !?
  • LeavingSunday
    by LeavingSunday » Sun Jan 10, 2010 1:55 pm
    boris wrote:This is weird...
    Hi Boris, Thx for the quick response! Indeed, it's a module problem. I found out that the conflict is coming from the padpal module. When enabled, it overrules the md8 transformer settings. Even when one of the transformer settings is enabled in the padpal module (matrix,..) the transformer button is dimmed when starting up the project.
